Need Help with Creating Shortcuts for Multiple Vaults in Obsidian
Hello everyone,
I have been using Obsidian for a while and have multiple vaults that I use regularly. Previously, I was able to create shortcuts on my desktop (and taskbar) for different vaults using a command like this:
C:\Users\Ravista\AppData\Local\Obsidian\Obsidian.exe “d:\Documents\Obsidian Vault”
However, after some recent updates, this method no longer works. Obsidian always opens the last opened vault instead of the specified one.
Is there a new trick or method to create different shortcuts for different vaults? Any help or guidance would be greatly appreciated!
Thank you in advance.
Best regards,
Ravista
I’d look into using https://help.obsidian.md/Extending+Obsidian/Obsidian+URI for something like this. e.g. [annex](obsidian://open?vault=annex) will open the “annex” vault when clicked.
For a desktop shortcut on Windows, you can right click on the desktop → NewShortcut → paste obsidian://open?vault=annex → give it a name → save → rejoice!
Screenshot 2024-05-21 084501
Screenshot 2024-05-21 084555
