When you are trying to organize notes into folders based on whether they are linked to or from a note.
Let it be possible to select multiple notes in the Backlinks or Outlinks panes and use a right click> Move to command to relocate them.
Current workaround
Use Database folder and filter an Outlinks or Backlinks column and use settings to move automatically based on a certain field, with a Select column for that field. This still requires going one by one.
Another workaround is to pin the note and open the Backlinks/Outlinks in new tabs and triggering a Templater script to move the note via a Hotkeys For Templater hotkey.
Use System search then cut and paste. But this doesn’t work for Outlinks.
Related feature requests
Related: Two suggestions for improving file relocation in Obsidian, and Copy page links from Tag and Backlinks Panes to clipboard
Thanks!
