Hi there
The Minimal theme is absolutely gorgeous and I really love it! Iām trying to get it to work with the RTL plugin, and it all works great after setting a custom font⦠except for task check boxes. They render like this with the check box on top of the text:
Turning off RTL fixes the the issue and it renders normally:
So it may seem like this is an issue with the RTL plugin and not Minimal, right? But the thing is, with other themes (such as Moonlight, Amethyst) this issue does not occur even with RTL support enabled. For example, with the default theme and RTL enabled:
This is a niche issue I guess, but would really love if you could help! I tried toggling things in the ul / li elements using the element inspector, but none if it helpedā¦
Thank you!
EDIT: Manually editing the theme CSS and disabling margin-left:-1.5em for .markdown-preview-view .task-list-item-checkbox did the trick!
But now it looks great:
