Updates to this: It seems to work after restarting Obsidian, with caveats:
- bullets work alright with spaces
- numbered lists don’t show any relationship lines unless I use tabs
It seems that some bullets/numbers get an “unmuted” style (made sure to update to the latest version and turned off all my snippets, and used tabs for this particular test):
Last but not least: There’s a new outliner plugin (which I also had off for the tests above), but I get something weird when using their snippet:
Can we make these two compatible?
And thanks as usual for the awesome theme!
