When the scrollbar is not visible, a middle click exhibits the same behavior in File Explorer and other core plugins: it opens the clicked item in a new tab.
When a scrollbar is visible in other core plugin tabs (Bookmarks, Backlinks, Tags, etc.), a middle click activates the scroll cursor, making it impossible to open a bookmarked item in a new tab with a single middle mouse click. This issue does not occur in File Explorer.
Provide an option to control middle-click behavior when a scrollbar is visible.
Use Ctrl + Left-Click to open the item in a new tab.
Obsidian version: v1.9.12
Installer version: v1.9.12
Obsidian version: 1.13.1
Installer version: 1.12.7
Catalyst license: vip
Insider build toggle: on
Plugins installed: 16
Plugins enabled: 16
Could this also be extended to the Quick Switcher and Command Palette on Windows? Currently, middle-clicking inside them activates auto-scroll. There shouldn’t be an action assigned to middle-click in the Command Palette, but for the Quick Switcher, it should open the note in a new tab. Thank you.
