Metadata changing between linked notes?
Hi all,
Similar to Nick Milo’s approach, I’ve been using “up” on my metadata to quickly navigate across my content. However, I am now having the following issue:
I have a parent note:
I navigate to one of the children:
Then, through the link in “up”, I try to go back to the parent note “History”
So, if I click off to a child note, the metadata of the parent note is changed so it’s identical to the child’s. Now the parent note is pointing to itself!
Has anyone had this issue, and is there a way to fix it? I have the latest version of Obsidian.
Does the issue seem similar to this bug report?
If so:
Oops, sorry, I hadn’t found that post - thanks a ton!
