+1 to have Mermaid Mindmap implementation.
+1 for mindmap!
+1, also waiting for it for a long time
+1 for mindmap
About âexperimentalâ mindmap from Mindmap | Mermaid
Mindmap: This is an experimental diagram for now. The syntax and properties can change in future releases. The syntax is stable except for the icon integration which is the experimental part.
I understand this text like this:
how to process icons we have not decided yet,
and in the rest we promise stability, i.Đ”. you can use the diagram
Embedding quadrant charts using mermaid doesnât work.
Upgrade mermaid.js to v10.2.0 which supports quadrant charts.
Is this implemented or not ?
Is it possible to do it manually locally and how ?
Mermaid will be updated to v10.2 in Obsidian Desktop v1.4. No ETAs on the release date.
Most excellent! Thank you. Just tried to use Mermaid the first time in obsidian and it didnât work. Excited to see it in the Desktop v1.4 release.
