Take a math formula: $x+y = 5$. ← This should render properly.
However, adding a space in the beginning or end will cause Obsidian to not consider this a formula anymore: $ x+y = 5 $ ← This will not be parsed as a formula.
I would understand why would the previous expression not be parsed as a formula in its final state, but, during typing $x+y = 5$ the interpreter constantly (for every space) switches from considering it a formula to not considering it a formula for each arising space. This messes up any additional command that would be using if we are inside a formula, and is visually unappealing.
Yes ![]()
Previously both expressions would render as math formulas. Now it’s not the case.
Obsidian version: v1.3.7
Installer version: v1.3.5
Operating system: Windows 10 Home 10.0.19045
Catalyst license: none
Legacy editor: off
Thank you ![]()
