Some of my vaults contain a bunch of git-repositories and therefore a lot of small files in .git. Would it be possible to a .obsidianignore file to the vault in which if can specify which files I would like to ignore during loading? And also not showing these files/folders in the folder structure within obsidian? Then i could just add **/.git/ to the .obsidianignore file and everything would be fine. ![]()
Large vaults with many small files load forever. E.g. with many git repos.
Add a .obsidianignore file to the vault where we specify which files/folder should be ignored.
No i guess?
Thanks for you work!
Regards
Max
