Make notes that appear in a base link to that base in graph view (act as a backlink)
Problem
The Bases plugin in Obsidian offers a powerful way to organize notes using database-like views. However, notes within a base are not currently represented as linked nodes in the Graph View, nor is the .base file itself visible. This limits the ability to visualize and navigate relationships between notes contained within a base.
Introduce an optional feature that allows notes within a base to be displayed as linked nodes in the Graph View. Additionally, make the .base file itself visible in the Graph View. This feature would be optional, enabling users to choose whether they want to visualize these relationships.
The bases itself is visible in graph view if you enable attachments.
I don’t think that just because two notes appear in the same base, they should be linked in the global graph view.
If you had a base with all notes, all notes would appear linked in global graph view.
If you change the filters in base (view), that would mean a change in the global graph view, this would also effect in/out-going links in the rest of the UI.
If you think about it, what you are asking implies that the global graph view should show a connection between two notes if they appear in any view of any base.
This also implies that before showing the graph view, we would have to run all bases and and all view and look for connection.
All of this doesn’t make sense and is not feasible either.
Having a local graph view for a base makes more sense https://forum.obsidian.md/t/base-add-a-graph-view-put-graph-view-in-bases-view-menu/104414
Thank you for your response! I wasn’t aware that enabling “Attachments” makes the .base file visible in the Graph View. I’ll start using that feature.
To clarify, my request isn’t to automatically link all notes within a base to each other. I would like the notes to be linked to the .base file itself, treating it as a central node. This way, my projects can appear unified in the Graph View, with the .base file as the central hub.
.base files have great functionality—much more than a regular text file or even a Kanban—but currently, they don’t show connections on the graph, which makes everything look disorganized. Linking notes to the .base as a central node would improve clarity and organization.
I understand the importance of maintaining control over the Graph View’s appearance. Therefore, I propose this feature be optional, allowing users to choose whether to enable it. This approach would provide flexibility while enhancing the visualization of project structures.
I think optionally adding this in the way you described is a great idea. Bases are flexible enough to cover a wide range of different use cases; I can see some where the graph reflecting the default view of a base would make sense.
In one of my simple cases, I like creating a ‘summary’ note of sorts for certain topics, a somewhat central note that explains and links to a bunch of different smaller notes. Maintaining these was somewhat cumbersome before bases, but now I can have a base to dynamically populate itself with all of these notes and embed that base into the summary note. Before, these notes would have appeared linked to the summary note on the graph. But since they’re now managed in bases, they appear as a ton of disconnected floating notes.
These notes are definitely all connected in their topic, so I think having a way to reflect this connection on the graph view aligns well with the spirit of graphs in Obsidian.
I appreciate your thoughts on the matter- but is the point of Obsidian not to cater it to each individual way of thinking? It is supposed to be our second brain after all.
I agree that isn’t feasible to just have on every base without any intent- it just wouldn’t make sense and could easily blow up in your face. But if a general-purpose solution is not feasible, my wish is that you make the formulas feature more powerful.
Problem
I had intended to dynamically determine which base each individual note should belong to using a formula (which I actually had working), only to realize that these formulas cannot edit other properties, nor is it a property in and of itself.
Why would I need to have a dynamic property? Well if a property can be a link, I can just dynamically create a link- potentially multiple if I wanted to, and I would have much more granular control over this- removing many of the issues you mentioned prior.
Proposal
Allow for users to create their own dynamic properties, either through the existing formulas system. which is already plenty powerful for this, or by some other means.
This is a great idea!
I don’t know anything about formulas, but I’d love to have this funcionality in any way. My graph looks so messy because of how disconnected the notes in a .base are…
I personally put a category property in each file (list), where instead of putting the value as just text, I use a link, so I can link the base file. In most cases where seeing that link is actually meaningful, the category itself makes sense. Only exception is when you have a base embeded inside a note and it’s only relevant for some specific section of that file, though I personally haven’t run into such a case yet.
Strong +1, and especially for the Local Graph.
Concrete use case: most of my notes are surfaced through Bases views rather than by explicit [[links]]. When I open such a note and look at the Local Graph (or the Backlinks pane), I only see its Markdown links - nothing tells me which .base files include this note. So “where is this note actually used?” means remembering which base has matching filters, or running a global search instead of just reading the graph.
What I would like to see (all optional, off by default):
  1. A .base file node in the Local Graph, with an edge to each note that appears in that base’s results - i.e. the base acting as a backlink source for its member notes.
  2. The same relation in the Backlinks pane for the current note (something like “Included in these Bases: …”), since that is the pane I check first.
  3. A guard so one broad base cannot flood the graph: a threshold/depth limit, or an explicit per-base “show in graph” toggle.
I understand the relationship is computed (the base’s filters determine the result set) rather than written in the note text, which is probably why it is not represented today. But Bases already knows the result set, so exposing it as an optional edge would make the graph answer “where does this note live?” instead of only “what does this note literally link to?”.
(Obsidian 1.14.4, Windows, core Bases plugin; vault with 10 .base files.)
A partial answer from the plugin side, since this may take a while in core: Tag Graph (disclosure: I made it) is a graph view you add to a base, so it draws exactly the notes in that base. It does not put the .base file into the core graph or the local graph, which is what Alex17 is after. What it does is give the notes of a base a shape: tags, folders and properties (including a link property like the category approach Wriggle164 mentioned) become hubs, and the notes gather around them instead of floating as separate dots.
