Make.md - sync spaces between devices?
Hi all,
I am using Make.md on both desktop and mobile. I use a separate settings folder for mobile, .mobile, whilst the default for desktop so it doesn’t switch my plugins off whenever I use my phone.
However, this means the changes to my spaces doesn’t sync across unless I manually copy the files over. Does anyone have any ideas if I can get the make.md folder in the plugins to mirror itself over in the .mobile folder?
Thanks
Spaces storage has been rewritten in the next version to not depend on plugin settings but will be stored as markdown files. This should solve the issue, but I will test whether having two different settings folders can cause any conflicts.
