- Turn off the
Use [[Wikilinks]]
option underSettings --> Files and links
. This will auto-generate markdown links for attachments. - Create or open a note.
- On a new line, drag and drop a local image file as an attachment.
- On the same line and immediately next to the first image attachment, drag and drop another local image file as an attachment.
- Resize the images as necessary so both images appear side-by-side in the editor. Or repeat steps 3 and 4 with smaller images.
- Switch to the reading view.
- The two images are now vertical as if they were placed on two separate lines.
Y
The steps were reproduced in the sandbox.
I believe the same bug was previously reported here: Cannot embed local images next to each other
But was supposedly to be squashed in version 0.10.10. (See last post in that thread.)
I have only used the now current version v1.5.3, and so am unaware if this was indeed fixed for that version or the bug has become reintroduced at some point thereafter.
This occurs with the Readable line length
option enabled or disabled and with sufficient note space/image resizing.
The expected behavior would be that the two images that were placed next to each other on the same line in the editor would appear as such in the reading view.
Instead, in the reading view, the two images are seemingly placed in two separate lines and thus are vertical of one another.
Obsidian version: v1.5.3
Installer version: v1.5.3
If the Use [[Wikilinks]]
option is turned on and one drags and drops two local files next to each other, then in the editor AND the reading view, both appear side-by-side as expected.
If utilizing the markdown links with files from the web, with their URL addresses, then the image files are still also side-by-side in both the editor AND the reading view.
I am a new user and adopter, so apologies if this is not actually supported, and is happenstance of things appearing in the editor versus how things are actually rendered. (As from some further reading it seems markdown, philosophically, adopts a “linearity” with the content. And so such side-by-side placements goes against this. I could be absolutely incorrect about this with my limited foray.)
Thank you for looking at my bug report.
