Live Reloading of Graph settings is broken // Groups and colors not synchronized between devices
Pay an account allowing to be syncronized between multiple support ( i have pc windows and an iphone with app). Create several nodes (on pc for instance) class them in different folders, then lets attribute groups based on path and set color for nodes.
But every time the groups and color disapear on the other device and are not synchronized.
None of what i have done worked, even trying to resync manually or disconect reconnect, nor uninstalling and re installing the app worked
See the same color and groups than on the other device
this seems to be the same behavior than
Even if it s a simple thing to have sync colours, It s very annoying when we have lot of nodes to handles
thanks. it seems that live reloading of the updated graph settings is broken.
If you let obsidian sync, then close and reopen obsidian, you will see the new settings applied.
will be fixed 1.7.2
