Setup:
- Select some text somewhere to fill the so-called “primary selection” in X11 (I haven’t tested with Wayland)
- Make sure it actually works when you intentionally middle-click somewhere in a plain text part of an Obisidian buffer
- Now place the text cursor somewhere to refer to after the following steps
Problem A (middle-clicking a link):
- Perform the above setup
- Middle click a link in a Live Preview mode
- Observe that it opens the link in a new tab
- Switch back to the original tab and observe that it also inserted the text from Setup step 1 at the editor position from Setup step 3
Problem B (middle-clicking a tab):
- Open a second tab from the current tab while in Live Preview mode, such as by ctrl-clicking a link (to avoid the middle-click problem)
- Middle click the new tab in the tab bar to close it and return to the original tab
- Observe that it also inserted the text from Setup step 1 at the editor position from Setup step 3
It should never insert text when middle-clicking on an interactive element like a link in Live Preview mode, or on the tab bar. Quoting myself from a previous incarnation of this bug report:
As described in the reproduction steps: middle-click paste triggers when it shouldn’t.
- Operating system: Linux (NixOS — with X11 windowing, as opposed to Wayland)
- Debug info:
Obsidian version: v1.1.16
Installer version: v1.1.16
Operating system: #1-NixOS SMP PREEMPT_DYNAMIC Fri Mar 3 10:56:18 UTC 2023 6.2.2
Legacy editor: off
Snippets enabled: 14
Plugins installed: 19
Plugins enabled: 17
1: Recent Files v1.3.5
2: File Explorer Note Count v1.2.0
3: Icon Folder v1.7.0
4: Style Settings v1.0.3
5: Supercharged Links v0.9.3
6: Hider v1.2.4
7: Quick Explorer v0.2.8
8: Contextual Typography v2.2.4
9: Emoji Shortcodes v2.2.0
10: Dataview v0.5.55
11: Obsidian Git v2.17.4
12: Auto Link Title v1.4.1
13: Omnisearch v1.12.3
14: HTML Reader v1.0.7
15: Force note view mode v1.1.1
16: Sync Graph Settings v1.0.1
17: Image Toolkit v1.3.1
This is re-post of [1.1.9] [linux] [appImage] mouse middle-click seems still got accident paste which was reported fixed in 1.1.13. The symptoms are identical between 1.1.9 and 1.1.16 — there has been no observable change. The reproductions from that bug are still reproducible for me in 1.1.16, but I’ve reworded them above to hopefully make them clearer.
I will say, just now I tried to reproduce this in a sandbox vault, and unlike my main vault it doesn’t happen every time, but instead somewhat randomly. But it’s still reproducible with repetition. I wonder if this suggests some kind of race condition.
