Linux: Images and PDFs don't load if vault contains accented letters such as é (non english, non ascii, cjk, Umlauts)
Put a .pdf file with a unicode character anywhere in the path (file name or folder name). Like ė, ų, ū and such. Try viewing it in obsidian. It is not opened. Rename it (or containing folder) to eliminate those characters, and the file is didplayed.
Yes, the Sanbox vault does behave the same.
Obsidian version: v1.7.7
Installer version: v1.7.7
Operating system: #52-Ubuntu SMP PREEMPT_DYNAMIC Thu Dec 5 13:09:44 UTC 2024 6.8.0-51-generic
Plugins installed: 26
Plugins enabled: 16
1: Media Extended v2.11.1
2: Taskbone OCR v1.0.0
3: Dynamic Table of Contents v0.0.27
4: Obsidian Enhancing Export v1.1.1
5: Local images v0.14.2
6: Copy document as HTML v0.4.3
7: Simple Embeds v1.14.1
8: Advanced Slides v1.20.0
9: Rich Links v1.2.0
10: Annotator v0.2.11
11: Full Screen Toggle v1.0.3
12: Character Insertion v1.0.0
13: Linter v1.27.1
14: Tidy Footnotes v0.1.2
15: Markwhen v0.0.3
16: ePub Reader v1.0.1
Tested this behavior on Ext4 and NTFS disks, in case it is a filesystem issue. Bug persists on both filesystems.
hmmm removing the no-sandbox (AppImage) actually fixed the problem to me!
I newly (since a few weeks) found this bug and reported it, see Embeds and images not shown when filename contains umlaut (ä, ü, ö).
Funnily enought, I only started with using snap to rule out influence of non-supported installation methods for reporting another bug…
Sooooo, I should just drop the snap and use which of the installation formats and from which source? Or are there other workarounds?
I had install Obsidian with the snap tool. I tried to launch it with the following command env LC_ALL=en_US.UTF-8 obsidian, which logged:
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
2025-07-22 12:08:46 Loading main app package /snap/obsidian/47/resources/obsidian.asar
2025-07-22 12:08:46 Checking for update using Github
2025-07-22 12:08:46 Success.
2025-07-22 12:08:46 Latest version is 1.8.10
2025-07-22 12:08:46 App is up to date.
Then, I uninstalled it and re-installed considering the .deb file downloaded from the Obsidian’s official downlaod website.
It works fine now!
Also this old bug - https://forum.obsidian.md/t/some-pdfs-are-shown-as-empty-in-internal-pdf-viewer/73058 - is about the same. It’s already archived and I cannot comment on it, so I’m hoping @isomattis found that snap is the culprit.
Same issue here - with German umlauts and with all Japanese characters.
It also leads to an hard Obsidian crash on drag-and-drop of such image files into the application. But strangely only if I start with the shortcut of the application launcher.
  • I’m on EndeavourOS (which is Arch Linux)
  • The desktop is KDE Plasma.
  • Official Obsidian AUR image: extra/obsidian 1.12.4-1
  • empty test vault / no plugins
  • As far as I see I’m on the locale/language setting that should work: System Locale: LANG=en_US.UTF-8
How it looks … with the top chapter using an image with only latin characters. And the second chapter using several images with Japanese ones.
The fix for me is to either launch the program via terminal - just with obsidian, no env settings necessary.
Or add the env=LC_ALL=en_US.UTF-8 to the start menu/launcher shortcut.
I have no clue why that is. Just clicking on the normal shortcut that Obsidian created on install, creates the issue.
It might be something specific about my language settings - but I don’t see a Format option that Gnome users mention. KDE allowed me to have different settings for how dates, currencies and addresses are displayed - maybe it’s that. Though it would be odd.
BTW I suspect that emojis and such in file and folder also create the problem. But I didn’t try around much.
Same issue with Kubuntu 25.10 (KDE Plasma 6.4.5) and french language.
Resolved by installing Flatpak version of Obsidian instead of Snap.
Hi everyone,
I’ve been following this thread and the upstream Electron bug for a some time. Since it bosers me and none rushing to fix it, I built a plugin that works around it: “Linux Image Rendering Fix”.
How it bypasses the bug
The plugin intercepts Markdown rendering via MarkdownPostProcessor, finds every <img> element, reads the image file directly from disk using vault.adapter.readBinary(), and replaces src with a Blob URL (blob:...). This completely bypasses the broken app:// protocol — no locale fiddling, no package switching, no renaming.
Features
  • Automatic — images are replaced on page open, tab switch, and file modification
  • Formats: PNG, JPEG, GIF, WebP, SVG, BMP, ICO
  • Reprocess Images command — manual refresh for the current view
  • Zero network requests — works only inside the vault
  • Zero configuration — install and forget
Coverage
I’ve tested every scenario mentioned in this thread and beyond:
  • Images embedded in a note — works
  • Hover preview (popover) — works
  • Viewing an image file directly — works
  • Images on inactive/background tabs — works (MutationObserver catches them)
There may be edge cases I haven’t found, but so far I haven’t seen a broken image the plugin didn’t catch.
Known quirks
Some scenarios have a slight delay on first load — the system needs a “warm-up” moment before the plugin kicks in.
Install
Community Plugins → Browse → search Linux Image Rendering Fix → Install → Enable
Repository: GitHub
Tested on Ubuntu 24.04 (DEB). Should work on any distro and package format — the root cause is the same upstream Electron bug.
Compared to workarounds in this thread
  • No need to rename folders to ASCII
  • No need to set LANG/LC_ALL
  • No need to switch from Snap to DEB/Flatpak/AppImage
  • No need to launch from terminal
One plugin, problem gone. Feedback and bug reports welcome on GitHub.
