Links in bases are not displayed in graph
I want to see the links in the bases to appear in the graph view.
I have created a learning.base and it contains work.md, personal.md and certs.md
If I created a note instead of base, I was able to see learning.md has link to work.md, personal.md and certs.md in the graph. But with learning.base, I’m not able to see work.md, personal.md and certs.md in the graph view.
Is there a way to see the links in the learning.base in graph view?
Wrote a message in order to keep the topic open.
what does it mean to have a link in learning.base?
I would like Obsidian functionality that allows to show links in bases in graph view.
which links in bases?
Can you provide an example with some screenshots?
For example, I created a folder and several notes inside it, and one of my notes has a database. Like the person in the thread, I want to be able to see (via a switch) in Graph view that my Note with base is linked to other notes.
Now I see this
But I want to be able to switch to this
Is there a supported way of doing this? I’m trying to use bases to generate dynamic MOCs, but as a result the links in graph view disappear.
The fact that some notes appear together in a Base does not constitute a link (in the obsidian sense) among those notes or between the base file and those notes.
You can make a FR for this, but to be frank this is unlikely to happen.
There is another FR that is asking to introduce a “local” graph view specific to the base. That feature request is somewhat similar in spirit but different in practice from what you described.
