Well, [[links]] are not a feature of Markdown, for one. But I’m not saying you’re right or wrong, just looking to have the conversation. How might links inside code be useful? How might it be problematic? What do others think?
I’m sorry if you thought that my reply was rude. I thought it was an obvious bug.
For example, in R programming language [[ is a an operator (see here)
Besides, I have just noticed that the same happens in math expression. And it may happens to write something like this $ [[5+44]*3] $
I use snippets of Programming RFC’s for research and a lot of the older ones use tabs for formatting. So in my use case I would prefer to escape the [[ in code if I were to write R or python snippets.
So maybe (and I can’t say how feasible this is in the current architecture) a solution could be to have the Unlinked Mentions exhibit normal behaviour (linking the notes) and have a set of sensible settings that can switch off this behaviour per use case?
Due to the prevalence of # as a character of significance in programming, and the fact that the user is currently editing a multi-line code block, which are almost exclusively used for snippets of code, I would expect nothing particular to happen.
The auto-complete fuzzy search dropdown list for existing tags was displayed.
Operating system: Windows 10 Pro, Version 1909, OS Build 18363.836
I can see how this is debateably a ‘bug’ and is just a design decision, and that users expect # to mean tag always. But imo the current behavior is incorrect; I was very surprised and thrown off.
I would expect both code blocks (block of text surrounded by ```) and inline code to not show the link autocompletion popup, especially since the links both don’t activate or report to the linked page as a backlink.
More importantly, I would want the code to be treated as that, code. Not markdown (or extended markdown, or Obsidian links, or anything other than code).
I am going to disagree with you and close this BR.
We now have many plugins that use codeblocks for various purposes, including special handling of text (like admonition). And you do want auto-completion in those.
Please, open a FR where you ask for selective auto-completion based on the type of codeblock. That is, if it’s text or some form of query, autocomplete, if it is code, do not autocomplete.
