Let regex work with tag: and section: search operators
To clarify, I want to note that this request has been edited as we incrementally realized that all but the tag: and section: operator already work. Originally, I was asking for something broader, as evidenced by the discussion below.
It could be helpful to use regex in conjunction with the tag: search operator in order to get fast results limited to tags while also using the magic of regex.
Let regex search work in conjunction with both the tag: and the section: search operator.
Thanks!
Regex already works with those things (at least path: and tag:; I didn’t check all). Is it not working for you?
Thanks so much! I was probably doing something careless when testing earlier, but it wasn’t working for me on Obsidian Desktop, granted I was so sure this wasn’t already implemented that I obviously didn’t test as thoroughly as I should have. Now, after just seeing your reply, I tried it on Obsidian Mobile and something like path:/.*\/media/ worked perfectly. This is so awesome!
I will mark this as a solution because I surely take your word for it. Tomorrow, I am definitely going to further investigate on Desktop, and worst case scenario could just create an isolated feature request if it turns out one or more of them don’t work. But, I am very excited to see this functionality. It is very useful.
It’s weird that I can’t get really get a tag: search to work on Obsidian Mobile at the moment. Again, I am probably doing something careless. I am sure I will figure it out later. Out of curiosity, could you add an example of a tag: search that worked for you. I am trying all sorts using syntax like tag:/.*/ and I still can’t get any results.
Thanks again for breaking this great news!
Oh, I misunderstood you! I thought you were trying to do something like /.+dog.+/ path:media. I’m glad it worked anyway, or that at least path: works. Now that I actually know what you want, I see that tag: doesn’t work for me either (on mobile or desktop, tried a few ways on desktop). I wonder if it’s related to the lack of autocomplete for tag searches.
Thanks! I adapted the request and am going to unmark this as solved so this topic doesn’t close and since I think the discussion here is better than starting anew. Again, I really appreciate that you replied and mentioned that it already works, even if there was a miscommunication on my part. Otherwise, I would never have realized that path:regex and file:regex searches already work.
It seems that section:(regex) kind of works but not really. I definitely am going to be looking deeper into all of them later. I will add more information as I find it.
Thanks for doing the research to find which ones work!
I’m not sure if regexes as used by Obsidian are line-based, but if so then we don’t need them to work with line:() — altho it’d be simpler and less confusing if they did.
I think you are right. For some reason when I just retested line: and section: it didn’t occur to me to add the parentheses like the popup suggests. And, they worked perfectly. In the past, I think I must have been using the parentheses incorrectly, causing the regex searches to behave unpredictably. But, now I can get all the search operators to work with regex except tag:. And, upon rechecking the search operators section in the help…
https://help.obsidian.md/Plugins/Search#Search+operators
… I realized that the parentheses are shown for all. So, I assume they are not required but allowed. Regardless, progress has been made. Thanks for helping move this forward. I guess I can just edit the request to allow regex to work with tag: now. Life is good.
Oh, good! I just noticed those parentheses in the help recently (I think when I was looking up file: and path?) and because I’d been successfully searching without them (I used quotes when needed) I guessed they’d just needlessly carried over a programming language convention into the documentation or something (what a charitable outlook! :roll_eyes:). I should start using them.
I’m hoping that the regex problem with tag: has the same root as the autocomplete problem so we can get 2 fixes in 1. :slight_smile:
I very much agree! Thanks again!
Upon further testing, it appears that section: actually does not work correctly with regex. It appears to behave just like line: or simply not specifying a search operator whatsoever.
I apologize to all for the confusion. From here on in, I will try to get to a more definitive conclusion before posting requests and edits.
Thanks.
Well, sometimes figuring these things out is a process. I end up editing half of my posts (including this one, to add this sentence).
Bumping this up. Having access to regex for tag searches would be very useful, particularly for the graph view with nested tags (#parent-child1, #parent-child2). Some of us use tags within note metadata (frontmatter) and so doing a regex pattern on the “#” character is not workable.
You can do plain-text regex search on frontmatter tags, too: something like /^tags:.*"example"/ (this one assumes tags are wrapped in quotes). (Obviously it’d be better for tag: to support regex.)
I’m a bit worried about performance when I migrate over my 10K Evernote notes. Think that’ll be an issue? Is there a way to limit the query’s scope to the top of the file (like bash’s head)?
I don’t think there is (check the help page for Search, and the regex documentation it links to) but I don’t think you need to worry too much about performance. I don’t have any frontmatter tags but I did a similar search for alias parts in my 8000-note vault on an iPhone 13 — first one took a few seconds, next one was nearly instant.
