When in fullscreen mode on macOS, the location of the button for toggling (opening and closing) the left sidebar remains consistent, in the upper-left corner of the screen to the left of the Files, Search, and Bookmarks buttons that appear when the left sidebar opens. When in window mode, however, the button gets pushed to the right as the sidebar opens, with the Files, Search, and Bookmarks buttons appearing to its left.
(The right sidebar button behaves the same whether in fullscreen or window mode, always remaining at the far right end of the top bar with the buttons associated with the right sidebar always appearing to its left.)
Button remains at the far left end of the top bar as it does for fullscreen mode.
Button moves as if attached to the right edge of the left sidebar as it opens/closes.
Obsidian version: v1.3.5
Installer version: v1.3.5
Operating system: Darwin Kernel Version 21.6.0: Mon Apr 24 21:10:53 PDT 2023; root:xnu-8020.240.18.701.5~1/RELEASE_X86_64 21.6.0
Catalyst license: supporter
Insider build toggle: on
Legacy editor: off
This is closely related to the feature request below, but the behavior I’m observing in fullscreen mode suggests that this may actually be a bug and that fixing the bug would accomplish the feature request.
Update: the button position also remains consistently on the left in the Windows version of the app. Apparently this is a macOS-only bug, probably due to the presence of the macOS window buttons in that corner affecting its behavior somehow.
Why would that be intentional? What is it about the presence of the window control buttons that makes it impossible to have the sidebar toggle button remain in place?
It’s not impossible, we don’t want it there. It’s an intentional design decision. Don’t use hidden frame mode (settings>appearance>window frame style) or use some custom css.
Ah, thanks for that tip. I had no idea that was an option. Yes, that solves a couple problems at once (this one and the no-draggable-area one). I still think there is value in addressing both usability issues in hidden frame mode (and this may motivate me to finally figure out how CSS works so I can create and share a solution), but for now, adding the frame will work.
