To input Korean text, I enabled/disabled “Vim key bindings” and/or “Use legacy editor”.
Vim key bindings
Use legacy editor
- Vim (Off) + Legacy (Off)
- Vim (Off) + Legacy (On)
- Vim (On) + Legacy (Off) ==> Problems happened.
- Vim (On) + Legacy (On)
Except the 3rd mode, it seems that everyghing is O.K for Korean Text input.
But, in the 3rd mode, I found two problems for Korean Input.
(In the 3rd mode, English Text Input is O.K.)
In the Korean Keybord state, even in the normal mode the Korean Texts can be input, abnormally.
I mean by "abnormally’ that Korean characters can be inpu, but when I input “.”(period), it works like ‘backspace’, so it deletes the inputs backward.
I guess that this is the same problem with Vim: Input when it's not in insert mode with Korean -
In the insert mode & Korean Keybord state, there is some lagging in text input and often it results in the missing character at the end of text input area.
From the image, the upper part is for the 3rd mode which has the input problem.
The lower part is for the 1st mode which is normal.
The lower part of the attached image.
The upper part of the attached image.
- Operating system: Windows
- Debug info:
Obsidian version: v0.15.9
Installer version: v0.15.9
Operating system: Windows 11 Pro 10.0.22000
Live preview: off
Legacy editor: off
Plugins installed: 0
Plugins enabled: 0
