@RobOK have you checked out my highlighter that also has a kindle highlights extraction which looks exactly like your screenshot? Completely 100% free! Would love your feedback.
Through Readwise, you can get an export to Notion (Free) that is very nicely formated and tagged. You can export to Markdown which looks great in Obsidian.
Here is what Notion does:
Here is what it looks like in Obsidian:
You eventually have to pay for Readwise, although they do have a free clipper called Bookcision. Here is the link for Readwise’s Bookcision: https://readwise.io/bookcision
Readwise has their paid version. My 30 day trial period just ended and now I have to pay for them to send my highlights to Notion. Or there’s their free version with Bookcision.
I’m also playing with how to effectively get .mobi formatted books and highlights I create on my iPad into Obsidian. One trick, if you are willing to use Readwise is that if you use the send to kindle app to send your personal documents to Amazon and then to your device then the highlights on those appear on the kindle highlights page.
Readwise pro offers markdown support.
OTOH then you are giving Readwise and Amazon info on your personal books.
I REALLY want a system that allows me to keep all my stuff contained on my own WebDAV server.
I can recommend this python script highly. Not too hard to use and if you have some python knowledge you can tweak it a little bit to your liking.
I just have to connect my kindle and start the script and than all my new notes are in my vault - sorted by book.
Hi everyone - fascinating thread. I’m trying to convert my my_clippings file to markdown and have tried a few of the scripts in this thread. Unfortunately, I can’t get any of them to work (here, I suspect this is down to the fact I have not used python or ruby before and don’t really know what I am doing). If anyone has had success with the scripts above, would you mind explaining in a bit more detail how you installed and used them (haven’t worked this out from their Read Me files yet). thanks!
Have you tried fyodor - it has very simple instruction on its github page.
Hi - yep. This is my ignorance of running scripts unfortunately, but I can’t seem to get it to work with Ruby (which I haven’t used before) [the instructions on the github just say install Ruby and run]. I’m not sure what the $ means for example (again, apologies - these are quite basic questions I appreciate)
What OS are you using?
You can ignore the $ at the start of the line. Just implies a new line in the terminal/Commend prompt. Copy and past the text excluding the $.
I’ve done this in Linux. Not done in Windows but will try if you need me to.
That is extremely kind - I am using Windows 10 Home. I shall give it another go ignoring the $ and see what it says. Do you happen to know if I need to navigate to the folder it is, when executing the command?
When doing the install, yes.
Or you can try include the path in the command. e.g. gem install c:/Downloads/fyodor but probably best to navigate there to avoid muddying the waters.
Just tested on Windows 10. Works. Let me know if you have any issues.
Assume you managed to install Ruby ok?
so I reinstalled Ruby which I think has helped. Extracted the zip for Fydor to a folder on my desktop. Ran the command and it states that 4 gems were installed which sounds good. Now not sure how to run the program itself/how to point it at the correct directories. I assume I just open Ruby start command prompt, type fyodor CLIPPINGS_FILE [OUTPUT_DIR] but I am not sure how to type out the clippings_file bit or [output_dir] in a correct form for Ruby (do you just copy the folder directory path?)
thanks for your help - really appreciate it!
Hi
Almost there… Don’t worry about Ruby again now that the Gems are installed.
  1. Open a command prompt and navigate to the folder containing My Clippings.txt. e.g. cd c:/user/downloads
  2. Decide where you want to store the output. Create a folder if necessary. I’ll assume c:\user\downloads\clippings
  3. Type fyodor "My Clippings.txt" c:\user\downloads\clippings
That should do it.
Hi
  1. Open a command prompt and navigate to the folder containing My Clippings.txt. e.g. cd c:\user\downloads
That should do it.
Thanks very much for your help - that got it working. Very grateful! Unfortunately, it seem to not have parsed quite a few of the documents so I will investigate (and perhaps to look into some other tools). Thanks all the same!
Where might I add my +1 to amplify or echo your feature request?
do any / all of these bypass the kindle highlight export limits?
Hi. Could you (or someone else), please, help with Fyodor on Mac? Ruby 3 installed, Fyodor Gems are installed. But when execute the command " fyodor /Users/name/Desktop/Clippings.txt", cmd returns “-bash: fyodor: command not found”
Readwise have added to the Markdown exporter, you can tweak some, not all, of the formatting.
