Is there any way to add multiple images at once to note or on canvas on Obsidian Mobile?
I want to pick multiple photos from the iOS photo picker after I tap the mobile toolbar button to insert. But it only lets me select one.
u can add note to canvas and inser image in it but it still lets u add just one at a time
FR:
I think an intermediary Shortcucts workflow would pay dividends. I know I did this years ago. Don’t ask now how.
Can you please elaborate or just tell me how to search on that because its really annoying.i found this plugin called simple image inserter but it doesnt work on mobile it wouldve been perfect
After digging some more i found a work around. On Iphone:
Create A note on your iphone note app
add all the pictures there
move the note but as markdown file not as normal text (there is a option when sharing called markup click on that) and move to the obsidian vault in your files it should be located in the On My Phone Folder . Just simply add it to the vault. Now here is a problem it shows up in obsidian as a pdf atlest for iphone you need to convert the pdf to markdown with this plugin called Marker PDF To MD by L3NOX . It lets you convert it amd after you convert it you have markdown note with all the pictures. Using that lets you add multiple pictures not having to add them one by one to the note. And if you want to add them to the canbas you simply drop the note in the canvas and you can drag and drop them out of the note onto the canvas. Really easy. This also can be automated and i hope some developer combines the process and makes it into a plugin! Im pretty sure it should work the same way on android or just find a app that lets u create markdown that lets you import multiple images and import it into the vault if it shows as pdf like in my case just convert it.
