Is there an elegant solution for capturing content from Twitter?
e.g. saving Tweets and Tweet Thread to markdown form.
I currently use markdownload for capturing articles, which is great, but I don’t think it’s optimized for saving tweets.
There is one tool called “therip” which does a good job saving tweet threads into markdown form, but it doesn’t work for tweets that are older than a week and doesn’t have a browser extension yet.
I am also looking for a solution for this.
I have found I built a free tool to save tweets and threads on Twitter to Obsidian but has the same limitations which threads older than 7 days
Hey there, I wrote a plugin called Tweet to Markdown that allows you to save tweets and threads in Obsidian, with no 7-day limitation. You can check it here:
Hope that works for you!
I personally use readwise for this, it autosaves tweets and threads directly to Obsidian that you answer to with for example “@readwiseio save thread”
I don’t use it just for this, but also for syncing my Instapaper highlights and Moon+ Reader Pro (Ebook reader android app) Highlights and notes on Obsidian automatically.
Works pretty well :slight_smile:
I need exactly this but with the ability to download all tweets from a profile into obsidian to be able to search from them and study later. If you are up for it… How much would developing this cost?
