Hi,
I would like to maintain rating for my notes, so that in long term I can review which ones are more useful to me. Any idea how can I do that with Obsidian? Thanks in advance for any hint.
Hi,
You can add metadata field with a rating. Add a YAML section at the top like this:
rating: 5
thank you for the hint.
From the Obsidian Help it seems it’s up to me how to use this metadata. So for example I can see the rating of each note when I view it, or search for all notes with a specific rating by a global search for rating: 5. Is there anything else that can be done?
You can use the Dataview plugin to create tables or list of notes sorted by rating, or filtered by a particular rating range.
More examples of what is possible can be found here:
