- Start obsidian 1.5.11 on linux
- Style a line to header (or checkbox and other styled line), note that level 1 header doesn’t have the problem, only 2 and above.
- Use fcitx5 input method to type in chinese
Y, I’ve tried in the sandbox and can reproduce the problem
The input method should not have anything leaked to obsidian since those characters are just encoding the corresponding Chinese.
The first typed-in character will be duplicated and appear after the input cursor.
Obsidian version: v1.5.11
Installer version: v1.5.11
Operating system: #1 ZEN SMP PREEMPT_DYNAMIC Sat, 16 Mar 2024 17:15:23 +0000 6.8.1-zen1-1-zen
Base theme: light
Community theme: Minimal v7.5.2
Snippets enabled: 2
Plugins installed: 29
Plugins enabled: 25
1: Advanced URI v1.40.0
2: Dataview v0.5.64
3: Latex Suite v1.9.1
4: Linter v1.23.2
5: Number Headings v1.16.0
6: Paste image rename v1.6.1
7: Periodic Notes v0.0.17
8: Zotero Integration v3.1.7
9: Templater v2.2.3
10: Tag Wrangler v0.6.1
11: Style Settings v1.0.8
12: Smart Typography v1.0.18
13: Shortcuts extender v2.2.0
14: Preview Mode Keybinds v0.1.2
15: Remember cursor position v1.0.8
16: QuickAdd v1.8.1
17: Kanban v1.5.3
18: Advanced Tables v0.21.0
19: Spaced Repetition v1.11.2
20: Minimal Theme Settings v7.3.1
21: BRAT v0.8.4
22: sync-to-xlog v0.2.1
23: Zoom v1.1.2
24: Omnivore v1.9.4
25: Vimrc Support v0.9.0
The above bug report has been tested reproducible on my machine on the following linux setups:
- Xorg
- Wayland
- Sandboxed vault
- With or without vim support
- With or without community plugin
- Source code mode
- Live preview mode
Additionally, I’ve managed to get normal behavior by reverting back to the 1.5.8 obsidian.
