- Open graph (sometimes a bug occurs in the list of notes, but in the graph it appears more clearly).
- Hover over several notes with the mouse while holding down Ctrl.
Y
- When I hover over another note (while holding down Ctrl) - I should only see its preview. All previously opened note previews in the Graph should be closed (except when I preview a link to another note inside a note, then displaying the stack is justified).
- [Feature request / QOL improvement] I should be able to force close all note previews by pressing Esc.
Very inconsistent behavior:
- Some hover previews do not appear on the first try.
- Some previews open on top of other previews.
- Some previews close. Some remain visible even when the graph is closed.
To close each note preview, you need to click on it so that it becomes focused (a border appears around it) and only then press Esc.
See attached screen recording:
Note: Unfortunately I didn’t manage to capture multiple previews of different notes opening at the same time (but it happens sometimes), but you can see that the notes preview doesn’t always appear (either the old preview is displayed or it just closes and nothing happens, although I expect the preview of the note I hovered over to open).
While recording, I continuously held down Ctrl.
Obsidian version: v1.7.7
Installer version: v1.7.7
Language: ru
Clean install, no extensions. Behavior also observed in “Obsidian Sandbox”. After updating the installer to 1.7.7, multiple opening of note previews became much less frequent (could not reproduce during screen recording), but note previews still sometimes do not open on first hover.
