I use obsidian for lyrics, I’d like to record my demos as a link in the lyrics md file. The audio fidelity is not feasible (Android) to use the inbuilt recorder. I have to manually import audio which is not conducive to creative flow.
I believe the same is true on windows 10 but I rarely use obsidian on windows so I’m not certain (on vacation so PC not present to test that it’s not a poor quality microphone problem). I haven’t tried on Linux/Ubuntu.
Use a better audio system that can select between different mics or something… I don’t necessarily understand the cause of the low quality.
I am currently recording audio with Samsung voice memo, using Samsung file manager to copy to obsidian directory, then adding an inline link to the audio file.
Same problem noted for iOS. I think this request is closed, though.
