I stumbled over a weird behavior with indentations in code blocks.
Consider a code block like the following where some lines are indented:
``` ab cd ef ```
I place the cursor in front of cd and press the space bar three times in short succession.
cd is now aligned with the other lines:
``` ab cd ef ```
When hitting the space bar fast enough, instead a . and a space are inserted and the first character is removed:
``` ab . d ef ```
Further observations
- This does not happen when I am typing outside of a code block
- There needs to be an indented line before and after the affected line
- The surrounding lines need to be indented with at least 3 spaces or one or more tabs
- reproducible in the sandbox vault
- Operating system: macOS Ventura 13.0.1
- Debug info:
Obsidian version: v1.0.3
Installer version: v0.15.9
Operating system: Darwin Kernel Version 22.1.0: Sun Oct 9 20:15:09 PDT 2022; root:xnu-8792.41.9~2/RELEASE_ARM64_T6000 22.1.0
Legacy editor: off
