Importing markdown (or textbundle) with images
I’m switching to Obsidian from the markdown-based app Ulysses. Trying to move over my notes in bulk, but some of them have images. Is there a way to get the images to import in line?
I’ve tried importing as textbundle files, but where the images should be, it says “click to create”.
In searching the forum, there’s a thread called “Highlights App - Exporting images in MD”. It seems to be reporting a slightly different problem, but maybe it would work? Since I don’t know anything about coding, this approach scares me, but I would be willing to devote some hours to it if it’s promising.
Does anyone have any insight into what might be going on and how to fix?
Thank you!
Are the images included in the exported textbundle files?
If they are included, you could ask at the obsidian-importer repo or try a third-party tool like Jimmy (I’m the developer). In any case, an example file could help.
Reference: Highlights App - Exporting images in MD
