If there are interline formulas ($$...$$), the outline will not be fully displayed
The exact trigger conditions for the “incomplete outline display” bug have not yet been fully identified. Currently, this issue occurs after inserting a large number of display math equations. It is suspected that the problem may be related to the placement of the $$ delimiters and line breaks.
For instance, directly wrapping content with a consecutive $$$$ pair (with no line breaks in between) versus using $$ to start the equation, adding a line break after the content, and then closing with $$ can result in completely different behaviors.
While the root cause of this bug remains unclear, a straightforward workaround is available: simply adopt the second formatting approach (i.e., $$ + content + line break + $$). Replace the inline math equations within the problematic outline sections with this display math format, and the corresponding outline headings will then display correctly as expected.
Y
windows11
The same issue has also been reported on the Obsidian Chinese Forum. You can search for the topic titled: “部分标题在大纲中不显示”
For block math we only support:
text
$$math$$
text
text
math
text
