I'd like to link to my current weekly, quarteryly and yearly note on my home page
I am trying to create dynamic links to my current weekly, quarterly and yearly note within my home page that I am formatting as a dashboard.
I have experimented with Templater but cannot find the correct instructions on how to create this function and I am unsure of which language to use and how to write the code relevant to create this function.
You can do this with using inline commands:
`$= '[['+moment().format("YYYY-MM-DD")+'|Today]]'`
`$= '[['+moment().format("MMMM YYYY [Woche] ww")+'|Week]]'`
`$= '[['+moment().format("YYYY - MM-MMM")+'|Month]]'`
Formatting belongs to your naming of the daily / weekly / monthly notes. Inserting the example above to your homepage will create something like this:
Referring filenames in this case would be:
Note: this is a feature of DataView that must be explicitly turned on in settings (Enable Inline JavaScript Queries)
This is very helpful macmorri. From the inline code you shared I was able to make links to my current week and quarter on my daily note. See belowe
$= '[['+moment().format("YYYY-[W]W")+'|This Week]]'
$= '[['+moment().format("YYYY-[Q]Q")+'|This Quarter]]'
May I ask:
What do the functions $= and + do?
How can I create links to yesterday and tomorrow using inline code?
Thank you for the recommendation Siiraa. I will look into the button functionality at a later date. For now I want to understand dataview and how it works.
$= is not a function. It introduces a following dataview js inline statement. You can read about this inside dataview documentation: DQL, JS and Inlines - Dataview
+ is just a concat. For example following concat …
'Hello winking' + '***' + ' bye winking'
… will result in …
Hello winking*** bye winking
For another day (like yesterday or tomorrow) you could modify the moment call just like:
$= '[['+moment().add(-1, 'days').format("YYYY-MM-DD")+'|Yesterday]]'
$= '[['+moment().add(+1, 'days').format("YYYY-MM-DD")+'|Tomorrow]]'
As you can see you can just add / subtract days from “your moment”.
