@temberature in this post writes a script to read the value of the metadata field timesViewed
whenever the note is opened and increase by one. I’m writing this post just to add more info in case someone needs a better guide on how to use it, and invite more discussion on how to make it better.
You will need to install MetaEdit and Templater plugins.
Step 1: Put this script into a template note
this.app.workspace.on("file-open", async (file) => {
const metaedit = this.app.plugins.plugins["metaedit"].api
const timesViewed = await metaedit.getPropertyValue('timesViewed', file);
console.log(timesViewed)
if(!timesViewed) {
await metaedit.createYamlProperty('timesViewed', 1, file)
} else {
await metaedit.update('timesViewed', timesViewed + 1, file)
Optional: If you want to not activate the script on certain notes, add this at the top of the script (thanks @The_Tablet)
if(file.basename === "name1" || file.basename === "name2") {
return
// ...do something
It’s because the callback for file-open
takes a TFile as one of its arguments, meaning you can check the TFile
’s basename in the callback
Step 2: Open Templater’s setting, choose that note as a startup template
You are done.
