desk7
1
Obsidian 0.12.19 on Windows 10
I use the outline plugin to show the vertical lines in bullet list but it works only in edit mode.
I would like to see them in preview mode so that the exported PDF shows them too.
My request is the same as this one How to print outliners lines in PDF too, (that, left side bulletin lines), which unfortunately received no answer.
desk7
2
I’m sure I need a CSS snippet for the preview mode but I can’t find it anywhere
@desk7 If you search the forum you will find a lot of info concerning your question. Below just some examples:
