How do you place the cursor using templater?
<% tp.file.cursor(1) %>
The text above is rendered. The placement of the cursor is not where the command was inserted.
<% tp.file.cursor() %>
As above
I want to place the cursor at a specific location in my note using templater plugin.
Your first option is correct. You just need to enable it in the Templater settings:
