I’ve searched this Forum, Help and Discord without finding a solution to why I can not successfully embed a PDF in a Note (PDF is saved in Attachments sub folder) then View the PDF in Preview similar to a JPG.
I’ve used the same procedure as embedding a photo (which works), but though PDFs are saved to the Attachment folder, -
(1) nothing shows up in Preview mode, and
(2) only “< >” showing in the PDF file.
I’m using the latest Obsidian mobile insider version on Apple iPad.
Is there a specific Settings toggle I need to turn on? If so, I haven’t found it.
