We strongly recommend you to search the forum with possible keywords before submitting a new bug report. Please also try your repro steps with third-party plugins and custom CSS disabled and see if it’s still reproducible. If it’s an issue with third-party plugins or themes, try contacting the author for help. Once you’ve done the above, delete this line.
- Insert PDF through transclusion (!) in a document
Inline rendering of PDF within the document
Blank white image. This is a simple two-page PDF. It renders perfectly in the desktop version of Obsidian but not in the mobile version
iOS/iPad OS version 14.6
I tested this using the default theme as well as a few community themes and I get the same result in both light and dark mode.
