How do I rename vault?
Hi there, is it possible to rename a vault? Thank you.
  1. go to your vault folder and rename it (outside of Obsidian)
  2. go to Obsidian vault options and “Open folder as vault” ( the one you just renamed).
  3. delete your old vault from the obsidian vault options.
Hope this works!
Thank you, it does. And it was easier than I thought.
I tried to follow this instruction but failed. What does “add a new vault” mean? That doesn’t appear as a choice. I tried creating a new vault with the name of the vault folder that I had renamed in step 1. All that did was to nest a vault within a vault, both having the same names. Thanks.
when u open the vault there are three choices, and the first one is 'open folder as vault, click this one and find the folder that u renamed, click it, then u got a new vault as same as before. Then u can just delete the old folder and use the new one.
thnx!
