This dataview-snytax finds broken links in my vault:
TABLE without id
out AS "Uncreated files", file.link as "Origin"
FLATTEN file.outlinks as out
WHERE !(out.file) AND !contains(meta(out).path, "/")
SORT out ASC
How do I get a list of broken links using the base syntax?
Thanks for your help.
Thank you, dawni; that works very well. I receive a list of files containing broken links. Is it also possible to display each broken link in a separate line?
As in give each uncreated note its own row? No, Bases doesn’t support that. Sorry it won’t look the way you were hoping! Each row in a base represents exactly one existing file.
