Header with a bullet point is not displayed in Outline
  1. Insert a Header
  2. Put a bullet point in it
  • Example: - #### graphic design
You should see the outline of the header in Outline
(made in Photoshop)
The header with a bullet point is not displayed in Outline
Just remove the hyphen, headers are rendered automatically in outline view.
This isn’t supported. There is a feature request you can upvote by pressing the heart button (or adding new info if applicable).
