I automatically assumed plus/minus would control zoom on the graph view. There should probably be buttons to change the zoom as well. maybe put them under the vertical menu (the one with split view).
graph view needs more controls:
keyboard navigation – shortcuts for zoom in/out – move with keys (ie : cursor) – reset/recenter graph view
on screen controls – buttons for zoom in/out – button for reset position/scale
I’d like an option to control Depth with keybindings in Local Graph. Can a user define shortcut keys for Graph View?
Depth
and this is related to Hot-key for depth of backlink in local graph - Feature requests - Obsidian Forum
