Graph view: Show note titles even when zoomed out
In a normal zoom level, the graph view shows note titles:
Zoom out a little bit, and the titles will shade:
Zoom out more, and the titles will disappear completely:
I’d like to be able to see note titles in the graph regardless of my zoom level. Maybe create an option for this in the settings?
Currently I just avoid zooming out.
Graph text fade threshold consider node size . This is a bit similar, but still a different thing.
Hey, I wanted to ask whether you found a workaround for this as I too have the same problem as you…
Hi. No, I haven’t found any workaround.
Does anyone happen to know if the texts could be made visible using CSS? I.e. are they originally hidden via CSS or JavaScript? If it’s the latter, then I guess it’s harder to unhide them.
