Garbled links from using Outgoing Links pane
  1. Have a vault with around 3,800 notes (not sure exactly how many causes this to happen, but my vault has 3,808 notes).
  2. Write out a note with a couple paragraphs.
  3. Open the outgoing links panel and start tapping suggestions.
  4. I tapped fairly fast in the attached video, but even slower tapping causes this bug eventually (the more notes you link, the worse it gets).
  5. Watch as all the outgoing links you tried to make become garbled and messed up.
The outgoing links to be linked where they’re supposed to be linked.
Garbled links.
  • Operating system: Android 11, but also occurs on Window 11
  • Debug info:
    Operating system: android 11 (OnePlus HD1925)
    Obsidian version: 1.4.1 (83)
    API version: v1.0.3
    Catalyst license: insider
    Legacy editor: off
Screen recording of the issue occuring:
I don’t understand your problem.
is it this https://forum.obsidian.md/t/linking-an-unlinked-mention-has-destructive-behavior-introduces-spurious-text-as-alias/18299
Yeah, that looks like it. I think it specifically needs you to have a larger vault to reproduce…
