I got help in this thread: Paragraph formatting in editor? - Help - Obsidian Forum
I added the following code to my Options > Appearance > CSS Snippets:
.CodeMirror pre.CodeMirror-line {
padding-bottom: 15px;
BTW I am only interested in Edit Mode. I generally never use preview mode.
This fixed the problem I was trying to solve, and introduced many new ones. Now everything has extra line spacing, including lists and headers.
After about 2 hours of floundering over the last several days, I have made no progress at all in finding snippets or anything I can make sense out of to adapt my own solution.
I just need to see paragraphs clearly without hitting enter 2x for every paragraph break, which will cause problems later in my workflow. That’s it. I just want any kind of traditional way to see single paragraph breaks WITHOUT ADDING EXTRA SPACE TO THINGS THAT ARE NOT PARAGRAPHS, e.g. headings, lists, etc
So I would like help accomplishing one of the following:
- Just change the vertical padding to a first-line indent for paragraphs so that vertical spacing is unaffected.
- Individually fix all lists and headers so that there is not a lot of extra vertical space
