In large document with many headings it is often easiest to just fold all headings and then manually unfold one heading. But, because I like having both Fold Headings and Fold Indent enabled, when doing this via hotkey, I have to manually unfold all the lists within the heading that I unfolded to begin working on.
If I could simply select a range of lines which contain folded lists and then press the hotkey for Unfold causing just the selection to be unfolded, this process would be much easier.
Related: Added hotkeys for Fold Headings and Fold Indents
Thanks!
