How do I filter a base to list recent notes from the last 30 days?
filters:
and:
- dateAfter(now(), dateModify(now(), -30 days))
- type: table
Any of this could change before the stable release, but currently…
The duration in dateModify is a string, so it needs quotation marks: “-30 days”.
Your filter compares “now” to “now -30 days”, which is always TRUE and would show every note. Now is always later than 30 days ago. So if you want to compare to the file’s implicit modified time (file.mtime), put that in place of the first now(). Like:
dateAfter(file.mtime, dateModify(now(), "-30 days"))
If you want to use a custom property that you manually update for the last modified date, put its name in there instead.
Maybe this could work
where dateOnOrAfter(property.Faellig, date(now()))
and dateOnOrBefore(property.Faellig, date(dateModify(date(now()), "7 days")))
thank you very much!
It’s a question I’ve been thinking about myself. Here’s what I came up with, to generate for each day a table with the following filter formula: dateEquals(date(file.mtime), dateModify(date(“2025-05-31”), “-0 days”))
This is a .base code-block that I’ve inserted in my “Daily Notes” template. My daily note title is formatted YYYY-MM-DD, and when I open it for the first time each day, I use a hotkey to run the command Templater: Replace templates in the active file. That gives me an .base table in my daily note. Very convenient. You do need the “Templater” plugin, though.
formulas:
Modified: ""
display: {}
- type: table
name: Modified on today's date code
filters:
and:
- dateEquals(date(file.mtime), dateModify(date("<% tp.file.title %>"), "-0 days"))
order:
- file.name
- file.mtime
- file.ctime
- file.folder
- tags
columnSize:
file.name: 490
file.mtime: 200
sort:
- column: file.mtime
direction: DESC
- column: file.folder
direction: ASC
limit: 50
If it’s in your daily note, I’m not sure you need the dateModify()
You could potentially use:
dateEquals(date(file.mtime), date("<% tp.file.title %>"))
This is untested though ![]()
Note that syntax breaking changes for bases were announced not too long ago on Discord for an upcoming release so this could potentially break at some point and you might have to edit your daily notes afterwards
Tested it with
formulas:
Date-Modified: date(file.mtime)
Date-Created: date(file.ctime)
- type: table
filters:
or:
- dateEquals(date(file.mtime), date("<% tp.file.title %>"))
order:
- file.name
- formula.Date-Modified
- file.folder
sort: []
- type: table
filters:
or:
- dateEquals(date(file.ctime), date("2025-06-01"))
order:
- file.name
- formula.Date-Created
- file.folder
sort: []
After Template Executes comes in empty
Can’t see the embedded templater syntax in embedded base
If I manually change to date though it shows nicely ![]()
Will keep working on it tomorrow ![]()
I don’t think there’s a way at this early stage of base development to programmatically access/read/parse/manipulate a .base file from within Obsidian
This will probably come when Obsidian’s API is updated to include base related things I guess
Using a base code block like AutonomyGaps did works though ![]()
You needn’t run Replace Template. Since the name or your daily note is YYYY-MM-DD, you can reference it as the date you want to modify:
dateEquals(date(file.mtime), dateModify(this.file.name, "-0 days"))
With that, you could put the full code block in your template if you want, or you could save it as a .base and embed it with only one line in your template:
![[modified-today.base]]
… or whatever you decide to name it.
Seems to sort of work but the results were incorrect
Original Base
formulas:
- type: table
filters:
or:
- dateEquals(date(file.mtime), dateModify(this.file.name, "-0 days"))
order:
- file.name
- file.folder
sort: []
- type: table
filters:
or:
- dateEquals(date(file.ctime), dateModify(this.file.name, "-0 days"))
order:
- file.name
- file.folder
sort: []
Embed in Daily Journal Template
RESULT
Different that Dataview Output
Okay. I was talking to AutonomyGaps’ about their use of date("<% tp.file.title %>") and “Replace templates” to insert a date that this.file.name can get from that day’s note.
I don’t know about your (or their) formulas. Or why you chose “-0 days”. But I hope it works out for you.
Options atm seem to be
1. The original embedded formula trigger by Templater
formulas:
Modified: ""
display: {}
- type: table
filters:
and:
order:
- file.name
- file.mtime
- file.ctime
- file.folder
- tags
columnSize:
file.name: 490
file.mtime: 200
sort:
direction: DESC
direction: ASC
limit: 50
2. Embed the Base then update manually
formulas:
- type: table
filters:
or:
- dateEquals(date(file.mtime), date("2025-06-01"))
order:
- file.name
- file.folder
sort: []
- type: table
filters:
or:
order:
- file.name
- file.folder
sort: []
3. Stick with Dataview for now
TABLE without ID
file.link AS "File",
dateformat(file.ctime, "yyyy-MM-dd") AS "Created"
FROM ""
WHERE file.ctime >= date([[<% tp.date.now('YYYY-MM-DD') %>]]) AND file.ctime < date([[<% tp.date.now('YYYY-MM-DD') %>]]) + dur(1 day)
SORT file.ctime DESC
LIMIT 10
TABLE without ID
dateformat(file.mtime, "yyyy-MM-dd") AS "Modified"
FROM ""
WHERE file.mtime >= date([[<% tp.date.now('YYYY-MM-DD') %>]]) AND file.mtime < date([[<% tp.date.now('YYYY-MM-DD') %>]]) + dur(1 day)
SORT file.mtime DESC
LIMIT 30
Still early days with Bases, Im sure will be more options in the coming weeks
Using dawni’s suggestion I seem to have it working, for files modified on a given day, without having to use a Templater replacement. It gives the same results as the dataview query I’ve used historically. Not sure if this will suit your needs:
base
filters:
and:
- file.folder != "Daily"
- file.ext != "base"
formulas:
display:
file.name: File
formula.Date-Modified: Modified
- type: table
filters:
and:
order:
- file.name
I’m using an embedded base rather than linking but it shouldn’t make any difference to the results.
This is the equivalent dataview code, with Templater replacing the day’s date:
dataview
TABLE file.mtime as Modified
FROM ""
WHERE date(2025-06-02T23:59) - file.mtime <= dur(24 hours) AND date(2025-06-02T23:59) - file.mtime > dur(0 hours) AND file.folder !="Daily"
SORT file.mtime asc
And here’s the results of both:
I just LOVE this community! Great suggestions. Thanks for taking what I had and running with it @PaulDickson @dawni @symph0nic !
Here’s what I’ve settled on for now:
My daily note embeds this .base note, with the view specified:
![[Table of modified on date in title of daily note.base#Today’s modifications]]
The elements that I include are the TIME of modification (I don’t need the day, since that’s in the title of the Daily Note). But I do like to have the Created and the Folder columns, for context. This gives me a really useful chronological overview of the day.
Thanks!
formulas:
ModTime: time(file.mtime)
display:
formula.Modified: Modified
formula.Created: Created
- type: table
name: Today's modifications
filters:
or:
order:
- file.name
- formula.ModTime
- formula.Created
- file.folder
sort:
- column: formula.ModTime
direction: ASC
columnSize:
file.name: 616
formula.ModTime: 131
formula.Created: 131
file.folder: 607
Nicely done. Yeah I was just using the date column to confirm the data was correct.
One thing that’s interesting, and may or may not be a problem, is that the list is not static. I.e. it isn’t a snapshot of the files that were modified on that day - if you subsequently modify a file it’ll disappear from the list for that original day and move to the current day.
As I said, this may not actually be an issue depending on what your needs are, but it doesn’t ‘freeze’ the data. I’m not sure if there’s any way of doing that and I’m pretty sure the old dataview method had the same ‘issue’.
That’s what we get using ctime and mtime; and throw syncing into the mix, things can get really off depending on the situation.
The only way to be 100% sure (and “freeze” the data) is to write the date into the file YAML/Properties itself and query those values. e.g.
dateCreated: 2025-03-19
dateModified: 2025-06-03
That doesn’t actually freeze the files that were modified though, as their modified dates will change later, potentially.
