Platform
[ ] iOS
[x] Android
Obsidian Mobile version: v1.4.1
Normally If I place a block that has width larger than Page Width of the Mobile, The page will extend for that only block.
Examples
- Tables with lots of content or columns
- Mermaid Diagram Larger than the page
- Images Larger than the page
In this case to check the remaining part of the block I will need swipe right to left the entire page. I think it would be better if can scroll only that element.
For Table, I want to set a parent column that will be static when I scroll.
I think this help request of mine is related to this.
For Mermaid Diagram, I think making it auto sized to fit the screen will be ok. To see a zoomed view touch the diagram for zoom glass or to view the full diagram open it separately by a click similar to an individual file.
For Image also similar to Mermaid
These are all what I think and would be better If had to enhance to Mobile User Experience.
If you also have any suggestions, ideas and expectations to enhance the Mobile Experience of Obsidian. I think you can mention it here. So the developers can consider implementing them on next update.
And let me know your Thoughts on my request.
