Currently, workspace is overwritten when you use the same folder for syncing the config between mobile and desktop Obsidians and some of the panes disappear on desktop, because they are not (yet?) supported on mobile. Example.
Please, ignore features not supported in mobile while syncing workspaces instead of overwriting the entire config.
