We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
The extract note feature needs the same option/drop-down for the new note location as creating a new note directly. I have new notes set to a specific folder (an inbox/triage), but if I’m splitting a note then I want the newly extracted note to be in the folder I’m working in. For example, if I’m splitting a seedbox (folder) note then I’m creating two seedbox notes, if I’m splitting a definition (folder) note, then I’m creating two definitions, etc.
Add exactly the same drop-down/setting for extract note that is present for new notes. This setting defines the location of the new note when the extract note function is used
Extract the note, then find it in the new note location and move it to where I want it to be (which is always the folder I’ve started from in my case/workflow).
Not a feature request, but a bug with the current way this feature works which is slated to be fixed in 0.12.6: Extract note does not honor "same folder as current file"
