Somehow I never considered putting my comments inside the highlights! I’ve been putting them immediately after the highlight (these are mainly notes on my own in-progress work), but inside might be better. Thanks!
This plugin is super amazing and I just love your enthusiasm @akaalias ! I have noticed that my exported highlights are all truncated to what appears to be an equal line length. It’s tidy, but I can’t read all the highlights in the final file. I have to go back to the original document to read them. When I watch your demos, your full highlighted text shows up after pasting, even if it’s long. Am I doing something wrong?
Hi @akaalias, I really like the Extract Highlights plugin and it makes life more fun. I just had a question. Is it passable to format how the highlight will be created? I really want it to be compatible with my Templater template for the note. I want to extract the key topics from test questions and then do a key topic note. so I highlight the key topics, extract the topics and then want to go and edit them. I have a template I want to use for them. Is there a way to say to the template to add any existing text to specified place? That could solve my problem. Ether way. Compatibility with Templater plugin?
Thanks for reading creating this plugin and all your efforts to improve it.
This is one of my most favorite plugins for shredding large content. It simply does something uniquely useful. Not too many plugins still have that going for them after 2 + years and no updates. Cheers to @akaalias !
Hi @akaalias! Great plugin. I tried to get this to work with Highlightr which uses <mark tags for the highlights. I couldn’t extract these, but normal == highlighted == text works fine. Any insight as to why it’s not working?
Also, I’d love to extract the color of each highlight, as with your examples on the PDF highlight extractor. Any plans to build this into the markdown highlight extractor?
Thank you!
Hi @akaalias , Thanaks for the great plugin Extract Highlight. I’ve been using for almost a year.
I’m using wondering if we could have an option to include the Title (#, ## etc.) in the extraction. This help to include the chapter, section heading of the extracted text.
Thank you very much!
The info on the plugin says it extracts “== , ** and <mark></mark>” but I’m using the last one i.e.</mark… and it’s not working. Am I missing something?
How do you do this?
I think it’s because the Highlightr plugin uses styled <mark tags.
@akalias It would be very nice if Extract Highlights could be updated to take the style attribute of <mark tags into account please!
EDIT: I haven’t attempted this yet but there is a potential solution here: FR: Make it work with <mark> attributes like <mark class="green"> · Issue #13 · akaalias/extract-highlights-plugin · GitHub
Seems I can only edit posts once.
Anyway, can confirm this works!
Hi, love this plug in and I’ve found it really useful. I would ask for one update if that’s possible at somepoint, and that’s to have an option to explode notes into a particular folder, in order to keep it organised.
for example, I have an inbox which is where all my unorganised notes go so that on a review day I just go through that content to summarise and relocate them. I’d like to do the same in this case.
Great plugin. Love it. Here’s my dream suggestion; I have no idea what is technically possible. Could a plugin option pull together all highlights from all notes within a specified Obsidian folder?
