Expand 'copy file path' with format options
As of 0.8.13, we now have the command+hotkey for Copy file path. This command copies the relative file path to the clipboard. If you are using a link format other than relative path, then this is not particularly useful.
I propose the ability to select the link or path format when you run Copy file path. A menu could be used that includes a variety of link formats:
  • (t) Title by itself
  • (s) Short format [[title]]
  • ('r) Relative path [[folder/title]]
  • (a) Absolute path [[c:\folder\title]]
  • (u) Obsidian URL obsidian://vault/vault-name/note title (this is available as of 0.8.15)
In parenthesis, I’ve suggested a hotkey that could be used after the Copy file path hotkey.
Numerous times I’ve thought that we really need a ‘copy absolute filepath’ command/hotkey in Obsidian so 100% agree with this request!
Yeah, full path is very required
Also it will be nice to have “Copy file path”, “Copy full file path” in this menu
There is a community plugin which does the job.
If anyone is still interested, I made a plugin for this: GitHub - shumadrid/obsidian-copy-path: A plugin for Obsidian that adds context menu actions for copying the full and vault relative path of a file/folder.
